2004 toyota corolla brake rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2010, 07:14 AM   #1 (permalink)
2004 Toyota Corolla
View billisnice's Photo Gallery
Front rotors. Are off brand rotors ok to use? If so, autozone or oreillys ok to use? Or another type ok to use.
Thanks
billisnice is offline   Reply With Quote
Old 10-03-2010, 12:10 PM   #2 (permalink)
Ohiowa's Avatar
View Ohiowa's Photo Gallery
I've used NAPA and Advance Auto Parts brands before without any issues I wouldn't have had with Toyota genuine.
Basically they're the same materials and specs, just not stamped with a Toyota logo. As disposable as brake parts are, I wouldn't spend any more than you have to. I would still buy the premium grade parts from the aftermarket parts stores, but they'll still cost less than factory parts.
Ohiowa is offline   Reply With Quote
Old 10-03-2010, 04:43 PM   #3 (permalink)
Gameroom cash: $188275
View sfcsky's Photo Gallery
if you get the pads with the lifetime warranty, you just have to replace them before you get down to the metal and you get the pads for free, but if you do not change your own pads, there is no real need for that since it would cost more to have someone take them around for you
sfcsky is offline   Reply With Quote
Old 10-03-2010, 04:45 PM   #4 (permalink)
I want to get some EBC dimpled rotors for the wife's car as it allows the gas not to build up between the pad and rotor, causing less heat spots and less pulsing with better feel and less fade
Old 10-03-2010, 04:45 PM   #5 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
the only advice i would offer when buying aftermarket brake parts from the parts stores would be to never get the cheapest parts whether it be pads, rotors, calipers, etc. as the cheap parts are not up to oem standards and can reduce braking and wear faster and whatnot. I usually get the premium parts as they most are most often oem spec or better.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 10-04-2010, 08:33 AM   #6 (permalink)
Ohiowa's Avatar
...I couldn't resist...
What kind of driving does your wife do that her brakes would be getting hot enough to fade?
Old 10-04-2010, 06:04 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1346597
+1
I would get Brembo OEM replacements. Good price/performance ratio.
I'd assume that she would have to do a lot of stop and go traffic and constatly ride the brakes on long downhills.
Old 10-04-2010, 10:59 PM   #8 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
what the cost of Brembo rotors, where's a good place to get em.
matrixjim is offline   Reply With Quote
Old 10-05-2010, 07:48 AM   #9 (permalink)
on full afterburner
Check out the Tire Rack.
They're prices are pretty competitive with other e-tailers.
Old 10-05-2010, 08:54 AM   #10 (permalink)
Ohiowa's Avatar
Their prices are pretty competitive with other e-tailers.
Agreed. The only issue is waiting. I tend to do my brake jobs on my days off, and since I work retail, they tend to be rather sporadic. I still end up buying from local shops because I need the parts sooner than I'm willing to pay added shipping for.
Old 10-05-2010, 10:18 AM   #11 (permalink)
View rsirois's Photo Gallery
If it's your first brake change, just inspect the rotors, you usually don't need to replace them. If they're in good shape, just replace the pads.
If you do need to replace them, I've found the brand really doesn't matter, but if you go for the cheapest aftermarket brand, they usually warp and you have a pulsing pedal after the first high speed stop.
rsirois is offline   Reply With Quote
Old 10-05-2010, 12:58 PM   #12 (permalink)
on full afterburner
So brand DOES matter.
As with most replacement parts, you get what you pay for.
Old 10-06-2010, 09:56 PM   #13 (permalink)
Ohiowa's Avatar
I think rsirois was implying that the low-grade options (regardless of brand) are not nearly as reliable as the "premium" grade components.
