Expansion Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2010, 04:41 PM   #1 (permalink)
View Gunruh's Photo Gallery
Expansion Valve
Does anyone know where the expansion valve is on a 2003 corolla? I can't find any literature on how to take out and put back in.
Gunruh is offline   Reply With Quote
Old 10-14-2010, 07:23 AM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
you're talkin about the A/C system expansion valve? should be near accumulator, don't know whether it's accessible from the firewall or if you have to get under the passenger-side dash or something , never replaced mine so idk.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 10-14-2010, 08:24 AM   #3 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327000
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
I am going to attach a link to show you where the expansion valve is located. You are looking for the 88515 which is attached to a pipe by the evaporator 88710A.
http://toyopartsman.webng.com/data/e...on%20valve.pdf
Hope this helps you out.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
The Following User Says Thank You to TOYOPARTSMAN For This Useful Post:
Gunruh (10-14-2010)
Old 10-14-2010, 08:47 AM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Who told you you valve is bad. Check out this thread first.
Replace 2004 Corolla Expansion Valve
mikered30 is online now   Reply With Quote
Old 10-14-2010, 07:11 PM   #5 (permalink)
Low is 20 / high is 225
Fans running high. washed condenser and radiator. Expansion valve is restricted and condenser has restriction. system does not balance. Need to replace valve and condenser.. all this according to the shop I brought it to.
Very helpful info.. couldn't find it in my copy of the Chilton's for my car. Thanks so much!!
Old 10-14-2010, 09:04 PM   #6 (permalink)
mikered30's Avatar
Relay ok?
Old 10-18-2010, 11:20 AM   #7 (permalink)
relay seems to be ok.Turned ac on and it seems to be working. Granted it is only 65 degrees out, but it was very cold air coming out.If there is a restriction in the system wouldn't that restriction always be there? I am thinking about having the system evaporated and refilled and then going from there. Is it normal that I can here a noise coming from under the dash sometimes when the a/c is running?
Old 10-18-2010, 12:11 PM   #8 (permalink)
mikered30's Avatar
What kind of noise?
Might want to ask for a full vac of the system and recharge.
Old 10-18-2010, 07:05 PM   #9 (permalink)
The noise is intermittent. I am not quite sure how to describe it. Kind sounds like air rushing into a cylinder maybe. Or like a balloon filling.. sort of. It didn't start making that noise until this year.
Old 10-18-2010, 09:18 PM   #10 (permalink)
mikered30's Avatar
Is your cabin air filter restricted?
Old 10-18-2010, 09:58 PM   #11 (permalink)
Tech1984's Avatar
Gameroom cash: $255850
View Tech1984's Photo Gallery
A restricted EXP valve puts the low side in the negative readings and blows warm air.
Consider full evac and recharge charging through the low side. 1.06 pounds.
Tech1984 is online now   Reply With Quote
Old 10-19-2010, 05:29 PM   #12 (permalink)
already changed the filter.Will do a full evac and recharge
Old 10-19-2010, 05:31 PM   #13 (permalink)
Onto another subject. What works to get rid of the sticky lifter noise that I am getting.I put a quart of transmission fluid in with the oil and let it idle. Noise is still there any other solutions?
Old 10-19-2010, 05:36 PM   #14 (permalink)
Tech1984's Avatar
Could be an exhaust leak noise and not a lifter.
Please don't treat your Toyota like an old Chevy. Put ONLY motor oil in the crankcase.
Old 10-19-2010, 06:54 PM   #15 (permalink)
mikered30's Avatar
Could the noise be the vsv clicking?
