Hi folks, I'll do an intro later, but I have a question first-
I believe I need to replace the left front wheel bearings on my '05 Corolla. Is it as simple as pulling the caliper out of the way and removing the staked nut? I'm thinking there is a pair of tapered rollers in there, but I don't know for sure. Any help would be appreciated.
No, the fronts need to be pressed, have a shop do the work or take off the knuckle and bring it to the shop and have them press the bearing out and in. Take it home and put the whole knuckle back in yourself. The rears are a different story. If you have ABS, be careful when ordering the correct part.
Thanks MikeRed30, that's about what I thought. I can get the thing off, easily enough. I really hate to pay for labor I can do. So, there's only one bearing in there?
HINT: Use the same procedures for the RH side and LH side. The procedures listed below are for the LH side.
REMOVE FRONT WHEEL
REMOVE FRONT AXLE HUB LH NUT SST 09930-00010
SEPARATE FRONT STABILIZER LINK ASSY LH
SEPARATE SPEED SENSOR FRONT LH (W/ ABS)
SEPARATE FRONT DISC BRAKE CALIPER ASSY LH
Remove the 2 bolts, separate the brake caliper assy LH from the steering knuckle.
REMOVE FRONT DISC
SEPARATE TIE ROD END SUB-ASSY LH SST 09628-62011
SEPARATE FRONT SUSPENSION ARM SUB-ASSY LOWER NO.1 LH
REMOVE FRONT AXLE ASSY LH
Using a plastic hammer, separate the front drive shaft assy LH from the axle hub.
NOTICE:
Be careful not to damage the boot.
w/ ABS: Be careful not to damage the speed sensor rotor.
Remove the 2 bolts, 2 nuts and front axle assy LH.
REMOVE LOWER BALL JOINT ASSY FRONT LH
Remove the cotter pin and nut.
Using SST, remove the lower ball joint assy front LH. SST 09628-62011
REMOVE FRONT AXLE HUB LH HOLE SNAP RING
Using a snap ring pliers, remove the LH hole snap ring.
REMOVE FRONT AXLE HUB SUB-ASSY LH
Using SST, remove the hub sub-assy LH. SST 09520-00031
Using SST, remove the inner race of hub LH bearing from the hub sub-assy LH. SST 09950-40011 (09951-04020, 09952-04010, 09953-04030, 09954-04010, 09955-04061, 09957-04010, 09958-04011), 09950-60010 (09951-00370)
REMOVE DISC BRAKE DUST COVER FRONT LH
Remove the 3 bolts and dust cover front LH.
REMOVE FRONT AXLE HUB LH BEARING
Place the inner race of hub LH bearing on the outer race of hub LH bearing.
Using SST and a press, remove the hub LH bearing from the steering knuckle. SST 09223-15020, 09950-60010 (09951-00640), 09950-70010 (09951-07100, 09387-02010)
INSTALL FRONT AXLE HUB LH BEARING
Using SST and a press, install a new hub LH bearing to the steering knuckle. SST 09950-60020 (09951-00720), 09950-70010 (09951-07100)
INSTALL DISC BRAKE DUST COVER FRONT LH
Install the dust cover front LH with the 3 bolts. Torque: 8.3 Nm (85 kgf-cm, 73 inch lbs.)
INSTALL FRONT AXLE HUB SUB-ASSY LH
Using SST and a press, install the hub sub-assy LH. SST 09608-32010, 09950-60010 (09951-00600), 09950-70010 (09951-07100)
INSTALL FRONT AXLE HUB LH HOLE SNAP RING
Using snap ring pliers, install a new LH hole snap ring.
INSTALL LOWER BALL JOINT ASSY FRONT LH
Install the lower ball joint assy front LH, torque the nut. Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
Install a new cotter pin.
NOTICE: If the holes for the cotter pin are not aligned, tighten the nut further up to 60°.
INSTALL FRONT AXLE ASSY LH
Push the front axle assy toward the outside of the vehicle, fit the splined part of the drive shaft assy to that of the front axle assy, insert the drive shaft assy into the front axle assy.
NOTICE:
Do not push out the front axle assy excessively.
Be careful not to damage the drive shaft outboard joint boot.
Install the 2 bolts, 2 nuts and front axle assy LH to the shock absorber. Torque: 153 Nm (1,560 kgf-cm, 113 ft. lbs.)
NOTICE: Only when reusing the bolts and nuts, apply engine oil to the screw part of the nuts.
INSTALL FRONT SUSPENSION ARM SUB-ASSY LOWER NO.1 LH
INSTALL TIE ROD END SUB-ASSY LH
INSTALL FRONT STABILIZER LINK ASSY LH
INSTALL FRONT DISC
INSTALL FRONT DISC BRAKE CALIPER ASSY LH
Install the brake caliper assy LH with the 2 bolts to the steering knuckle. Torque: 107 Nm (1,089 kgf-cm, 79 ft. lbs.)
INSTALL FRONT AXLE HUB LH NUT
Using a socket wrench (30 mm), install a new hub LH nut. Torque: 216 Nm (2,203 kgf-cm, 159 ft. lbs.)
REMOVE FRONT DISC
INSPECT AXLE HUB BEARING LOOSENESS
INSPECT AXLE HUB BEARING RUNOUT
INSTALL FRONT DISC
INSTALL SPEED SENSOR FRONT LH (W/ ABS)
Using a chisel and a hammer, stake the hub LH nut.
INSTALL FRONT WHEEL Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
INSPECT AND ADJUST FRONT WHEEL ALIGNMENT
CHECK ABS SPEED SENSOR SIGNAL (W/ ABS)
__________________ 2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi 2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
Thanks, dorman68. I ended up not being able to get the axle nut off- the 1/2" impact I bought in 1976 when I repaired cars for a living is getting weak- so I took it to a shop I trust and had them do it. $500 later, it's nice and quiet. I'll have to tackle this next time, and save myself about $300.
I will say here that I'm a bit disappointed with my Corolla. It's had a water pump, right rear wheel bearing and hub and a transaxle replaced in 98,000 miles. Now, a front wheel bearing and hub. Frankly I expected a lot better than that. Repairs now total more than one third the purchase price.
'nother update- subsequent to the replacement of the transmission, I'm hearing a noise that I'm pretty sure is indicative of a trashed crankshaft thrust bearing. It's going to the dealer tomorrow. I'm bummed, it's out of warranty...didn't make it to 100,000.
