2004 Corolla Center console light bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2010, 02:13 PM   #1 (permalink)
View rod758's Photo Gallery
Hi all,
The light bulb on my 2004 corolla behind the climate control knob has burnt out. How does one go about changing these? Also what bulb number is it and how many are behind this console? Thanks!
rod758
rod758 is offline   Reply With Quote
Old 11-02-2010, 09:53 AM   #2 (permalink)
View am_beagle's Photo Gallery
The bulb size is not mentioned in the user manual. Best way is to take it out to take a look. Here's how:
-Pull the middle knob out (Fan speed, I remember) you'll see a screw. Unscrew it then pry out the mid-console face with a flat plastic screwdriver/ or with your fingers. Be careful with the harness behind the control.
If you can disassemble the climate control box, you'll find the bulb.
Good luck.
am_beagle is offline   Reply With Quote
Old 11-02-2010, 11:11 PM   #3 (permalink)
Thanks for the response. When the center console is removed, does it just snap out from under the radio and above the shifter (automatic)? And what about the two other knobs, does it come out with the console?
Old 11-03-2010, 01:05 PM   #4 (permalink)
Yes. You're correct. The 2 other knobs come out with the console, you don't have to remove them until you disassemble the climate control box behind the console.
Old 11-03-2010, 07:49 PM   #5 (permalink)
Ok thanks!
Old 11-04-2010, 10:20 PM   #6 (permalink)
Hi rod,
Here's the link for the video to see how to remove the climate control bezel:
Finally! A fix for those damn blanking clocks!
Old 11-05-2010, 09:37 PM   #7 (permalink)
That helps a lot. Thanks! I think it's gonna take a lot of force to pull out that center face. Looks like I have to remove the panel around the shifter too.
Old 09-23-2011, 07:02 AM   #8 (permalink)
View eduardnic's Photo Gallery
Hi ROD!
I have 2003 Corolla and the same problem, some light not working; did you manage to find the code for the light bulb?
Thanks!
eduardnic is offline   Reply With Quote
Old 09-23-2011, 09:26 AM   #9 (permalink)
winkzoot's Avatar
View winkzoot's Photo Gallery
I had the same problem in my 05 XRs. It is a tiny peanut bulb and there are three of them. The dealer was only place I could find them, but they were pretty cheap.
winkzoot is offline   Reply With Quote
Old 09-23-2011, 09:44 PM   #10 (permalink)
I didn't end up taking the console out to find out because one day, the seemingly dead bulb came on. So, it's not dead but there's something else going on in there that I don't know. It lights up only occasionally. To this day, most of the time the light is out. Any other ideas would be appreciated.
Old 09-23-2011, 10:02 PM   #11 (permalink)
Gameroom cash: $103000
View shoujiliuzhijun's Photo Gallery
http://www.9thgencorolla.com/forum/s...ad.php?t=22150
One of the bulbs at that area is smaller than the others. You can also use new LED bulbs.
shoujiliuzhijun is offline   Reply With Quote
Old 11-23-2011, 09:25 AM   #12 (permalink)
View pattytoy06's Photo Gallery
That's incorrect. I checked one of the dealers in San Diego, CA and each one of those tiny bulbs are $10.00 each. And trust me I asked twice. I'm pretty sure my 2006 Corolla had two bulbs. I never replaced them and I don't miss them, since they were burned out when I bought the car.
pattytoy06 is offline   Reply With Quote
Old 11-23-2011, 04:07 PM   #13 (permalink)
View kevbot13's Photo Gallery
If you're talking about the HVAC lights, my 05 Corolla has two of them (green lights) The bulb is a neowedge type B if I remember correctly (base is 10 mm) I recently bought a few from autoillumination.com but they haven't come in yet, hope that helps
-Kevin
kevbot13 is offline   Reply With Quote
