08 Stereo Install Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2010, 12:42 PM   #1 (permalink)
View eilliam's Photo Gallery
Hi, I searched and couldn't quite find definite answers to my questions so here goes:
I got a new(to me) car. A 2008 Corolla S, Stock AM/FM/Disc unit, with 6 speakers(no disc changer). I want MP3 capabilities so I want to replace the head unit only.
With the 6 speaker system do I have an amp to bypass. If not, do I need to concern myself with the impedance of the stock speakers matching.
Basically If I can buy the stereo, harness, and install kit and just wire and swap I'm gonna go for it. If not, then I'm just going to buy an FM transmitter for my iPod. (I've installed about 10 systems before, just never on a Toyota)
If this stuff has already been answered please direct me to the thread, I was having issues finding it.
Thanks in advance
-eilliam
eilliam is offline   Reply With Quote
Old 10-28-2010, 02:07 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
With the 6 speaker setup there is no amp to bypass. There was only a separate amp with the optional JBL system.
A simple Toyota radio harness adapter will allow you to connect an aftermarket deck to the plugs that go into the stock unit. The antenna plug will go right in with no adapter.
You shouldn't have to worry about the impedance of the stock speakers. I believe they are simple 4 ohm speakers. They will sound MUCH better with an aftermarket deck. The stock decks are ~100 watts, and the JBL system was 180 watts, but used the same speakers (albeit with 2 more passive tweeters in the rear) so the speakers match to an aftermarket unit much better than the regular stock ones.
Be careful removing the bolts that hold in the stock radio. There are 4 of them along the bottom far back in the dash. They are easily dropped and lost. Also, the plastic clips where the bolts go on the dash kits for aftermarket units tend to break easily, and if you don't have all 4 the assembly will tilt down slightly resulting in a slight gap between the top of the dash kit and the vent assembly...I learned this the hard way after breaking one of the clips.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 10-28-2010, 02:14 PM   #3 (permalink)
Thanks for the speedy reply, but now that you mention it, i never thought to look for 2 more speakers in the back. Is there a way to tell if I have the JBL package with the amp or not? The car has leather and several other extras, and I don't have the original information sheet that it was sold with.
Old 10-28-2010, 02:34 PM   #4 (permalink)
If you had the JBL system you would have the 6 disc changer and a JBL logo on the stock unit. Hardly any corolla's were sold with it, just like the stability control option...I think they were both part of the same package on 05-08 models.
Old 10-28-2010, 02:50 PM   #5 (permalink)
Thanks again! I think i'm gonna buy a FM Transmitter for the moment, and start searching for the perfect head unit for this swap. Looking at some of the other posts, the install itself doesn't look very hard, compared to the other vehicles I've worked on.
Old 10-28-2010, 03:16 PM   #6 (permalink)
The install is not bad at all. The instructions may tell you that the center stack panel (HVAC controlls) needs to be removed, but really it just needs to be tilted forward a bit and not removed completely.
Also, be careful when pulling the vent assembly out from around the stock deck. There are some spots where it catches and can rip the face off the stock deck if you're not careful.
Old 11-01-2010, 03:16 PM   #7 (permalink)
View cambo16's Photo Gallery
Haha, be careful, it's a slippery slope. I just bought a head unit and new rear speakers. I told myself I'd keep it simple since i'm 26 and not in high school anymore, but now i find myself looking at subwoofers and boxes and amps. I feel like i'm 16 again.
2005 Corolla LE
1994 Xtracab DLX 4x4 22re
Stock.
cambo16 is offline   Reply With Quote
