2003 corolla lukewarm heat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2010, 04:39 PM   #1 (permalink)
View willy65000's Photo Gallery
I've been having this problem with my corolla for the last couple of years. All vents on the right side of the car blow lukewarm. I've already purging the air from the system and that doesn't do the trick. Also, the car seems to be at the correct operating temp (middle of the gauge). Any ideas?
willy65000 is offline   Reply With Quote
Old 11-23-2010, 07:52 AM   #2 (permalink)
View dorman68's Photo Gallery
I would check the 2 hoses (inlet & outlet)going to the firewall feeding the heater core. They both should be the same temperature, if one hose is hot and the other one is cold chances are you have a clogged heater core. If both hoses are hot I would check the temperature cable going to your heater controls and make sure everthing is operating properly, check for a binding or loose cable.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 12-02-2010, 10:09 PM   #3 (permalink)
View ratko89's Photo Gallery
maybe a slightly open thermostat
ratko89 is offline   Reply With Quote
Old 12-31-2010, 08:15 PM   #4 (permalink)
View dballard18's Photo Gallery
Possiblity
I have a 2002 Corolla and had a plugged heater. The garden hose would blow through it, but the litle water pump would force very little through it. I went through it last weekend and fixed it by pulling the heater hoses and backfilling with a drain cleaner to chemically clean the heater. Worked wonders. The details are in my post in the 8th gen forum, dballard18.
dballard18 is offline   Reply With Quote
Old 01-02-2011, 04:17 AM   #5 (permalink)
View ryfly's Photo Gallery
Clogged Heater core on the passenger. Be sure to find out first what clogged it before replacing or fixing.
ryfly is offline   Reply With Quote
