Help check engine light
Corolla 2005 CE manual transmission.
Check engine has been on for a while, I took to autozone, codes came up as follows:
P0455 and P0441
Based on possible causes I am not sure what to check
any hints ?
Below are possible problem areas.
P0441
Evaporative emission control system incorrect Purge flow
Probable cause:
Leak in EVAP system
Blocked EVAP purge line
Faulty purge VSV
P0455
Evaporative emission control system pressure leak
Large Leak
Faulty fuel cap ( I have already replaced it )
EVAP Line Leakage
Pump module failure
Canister faulty
