oil control valve filter on 1ZZ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2010, 11:27 PM   #1 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
Is there a oil control valve filter on 1ZZ engine?
matrixjim is offline   Reply With Quote
Old 12-01-2010, 06:19 AM   #2 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
yes there is......you need to remove the oil control valve to get at it....I have not done it on mine yet...I believe it is on the drivers side below the valve cover going into the head......it is one reason whenever your check engine light comes on you should read the codes........if there was an issue with your VVT it should throw a code and the filter might be the culprit....
everyone should own a code reader...I bought my codekey reader at Costcos for $19
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 12-01-2010, 05:13 PM   #3 (permalink)
Should the filter be inspected and replaced/cleaned as preventative maintenance.
Is there any good instruction on the removal.
jim
Old 12-01-2010, 07:33 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Instructions: http://www.diymytoyota.com/celica/oc...-vvt-i-vvtl-i/
http://www.corolland.com/forums/inde...tenance-items/
mikered30 is online now   Reply With Quote
The Following User Says Thank You to mikered30 For This Useful Post:
matrixjim (12-01-2010)
Old 12-03-2010, 05:10 PM   #5 (permalink)
mikered30's Avatar
I believe the gasket on the bolt is bad on my car. I have a bit of oil below the OCV filter.
Old 12-22-2011, 04:13 PM   #6 (permalink)
View gingn's Photo Gallery
im going to clean my ocv valve filter tommorow. any reccomendations?
gingn is offline   Reply With Quote
Old 12-22-2011, 04:13 PM   #7 (permalink)
or tips?
