Going in for Ontario Emissions Test - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 12:19 PM   #1 (permalink)
View ofogao's Photo Gallery
Canada Going in for Ontario Emissions Test
I have a 2004 Corolla with 180 , 000 kms.
I just change the oil (Synthetic) and did a drain and fill on the tranny fluid.
My plugs were change at about 130, 000. If I did change plus what would someone recommend? Keep in mind I'm located in Canada.
Apart from the above is there anything else you might recommend.
Thanks in advance.
Cheers
ofogao is offline   Reply With Quote
Old 12-29-2010, 03:56 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Do you think you will have a hard time passing or did you barely pass last time?
Plugs are probably fine as long as they were iridum plugs installed last time. If you think you need to change them, go with NGK or Denso iridium. May want to clean the throttle body and IAC valve. This guide can help you clean them and you do not have to remove the TB or IACV from the car. Just spray the TB and the little port in the TB.
http://matrixowners.com/index.php?showtopic=65513
The best advice before doing an emission test appointment is to drive the car at least 30 minutes (fairly hard) right before you go in.
mikered30 is offline   Reply With Quote
Old 12-29-2010, 09:08 PM   #3 (permalink)
View jeff1000's Photo Gallery
Just don't go to Canadian Tire. They do a brisk business failing vehicles in
the emissions test and then informing you that hundreds of dollars in
repairs are needed.
jeff1000 is offline   Reply With Quote
Old 02-06-2011, 08:42 PM   #4 (permalink)
View wilbour's Photo Gallery
repairs are needed.
Is that even possible? Purposely failing e-tests? I don't know about this.
wilbour is offline   Reply With Quote
Old 02-06-2011, 09:46 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1345697
In theory there is a possibility but in practice I don't see how it's even possible.
The test has to be run in accordance with specific guidelines and procedures.
Old 02-07-2011, 10:30 AM   #6 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
Could fail if test is ran without warming up engine.
matrixjim is offline   Reply With Quote
