Originally Posted by wireman134
In a manual tranny with drive by wire. At approx 2k rpm with pedal to floor does the fuel injection dump fuel or is the fuel mixture optimized for greatest efficiency.
The fuel mixture is optimized for greatest efficiency. This is the case for both cable-actuated and drive-by-wire systems.
My 03 manual vibe without drive by wire only achieved 39. With the manual 07 corolla I can regularly achieve 45-49 in warmer weather.. I am interested in learning why this drive by wire technology seems to be so effective. What does the cpu do to the voltage detected from the pedal? THANKS.
In a drive-by-wire system the CPU controls the throttle plate opening with a small motor mounted on the throttle body. I would suppose that the CPU might not open the throttle plate fully in low rpm situations because it would result in low air velocity, but I don't think it is very important in fuel injection systems.
In both systems the primary factors in the fuel map are intake air mass over time and feedback from the oxygen sensors in the exhaust. I think the differences in your fuel mileage are more due to other factors such as aerodynamics, tire pressure and rolling resistance, weight, intake and exhaust flow.... Did the 03 engine have VVT?
