Can I use a longer Serpentine Belt in 1ZZ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2011, 11:55 AM   #1 (permalink)
View Leo9897's Photo Gallery
According to other posts the replacement for the Serpentine Belt is 6PK1880, for a 2003 Corolla with 1ZZ Engine and A/C, is this correct?
But, I got here in Buenos Aires from the dealear a Bando 6PK1930 belt (Made In USA), this is 5 centimeters longer than the original I think.
They said that I can use these belt too without any problems... is this correct? Should I adjust the pulleys after replacing the belt to fit the 1930 mm long belt?
Thanks.
Leo.
Leo9897 is offline   Reply With Quote
Old 01-05-2011, 02:30 PM   #2 (permalink)
SOLVED: For Brazilian-made 9th gen Corolla 6PK1930 is the correct serpetine belt to use.
Old 01-06-2011, 07:14 AM   #3 (permalink)
View ryfly's Photo Gallery
Solved or not, you can adjust the tension to make it fit. 5cm is within range but i wouldn't push it.
ryfly is offline   Reply With Quote
Tags
6pk1880, 6pk1930, belt, sepertine
