2006 Corollla S Remote Start - Viper 5301 with Canmax400DEI - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2011, 01:24 PM   #1 (permalink)
View valliyappan's Photo Gallery
I did the same setup with the Viper 5301 and Canmax400dei on my 08 TL S and works great, now trying to do it on my 06 Corolla S. I think I got most of the wiring, but am unsure about a few things.
First question is what information is available on the can bus data network, brake status/door trigger/etc?
I need the color of the wire which is for the auto light, located at light switch in the steering column.
Also if someone could verify the color for the door lock/unlock
Primary harness (H1), 12-pin connector, WIRE COLOR
H1/2, RED, (+)12v CONSTANT INPUT----------------------------------------------H3/5 [RED]
H1/3, BROWN, (-) HORN OUTPUT-------------------------------------------------GREEN/YELLOW
H1/5, BLACK, (-) CHASSIS GROUND------------------------------------------------GROUND
H1/6, VIOLET, (+) DOOR TRIGGER INPUT*---------------------------------------NOT SURE IF I NEED TO CONNECT
H1/8, GREEN, (-) DOOR TRIGGER INPUT*----------------------------------------NOT SURE IF I NEED TO CONNECT
H1/11, WHITE, PARKING LIGHT OUTPUT ----------------------------------------GREEN/WHITE
Auxiliary harness (H2), 18-pin connector,
H2/9, VIOLET/WHITE, TACHOMETER INPUT-------------------------------------VIPER HAS VIRTUAL TACH
H2/18, BLACK/WHITE, (-) NEUTRAL SAFETY SWITCH INPUT-----------------GROUND
Heavy gauge remote start, (H3) 8-pin connector, WIRE COLOR
H3/1, PINK, IGNITION 1 INPUT/OUTPUT----------------------------------------- BLACK/WHITE
H3/2, RED/WHITE, (+) FUSED (30A) IGNITION 2 -------------------------------H3/5 [RED]
H3/3, ORANGE, ACCESSORY OUTPUT---------------------------------------------BLUE/RED
H3/4, VIOLET, STARTER OUTPUT---------------------------------------------------RED
H3/5, RED, (+) FUSED (30A) IGNITION 1 INPUT---------------------------------WHITE
H3/6, PINK/WHITE, (+) IGNITION 2 -----------------------------------------------BLACK/YELLOW
H3/8, RED/BLACK, (+) FUSED (30A) ACCESSORY/STARTER INPUT---------H3/5 [RED]
Door lock harness, 3-pin connector,
WIRE 1, BLUE, (-) 500mA UNLOCK OUTPUT------------------------------------BLUE[NOT SURE/WIRE COLOR]
WIRE 3, GREEN, (-) 500mA LOCK OUTPUT--------------------------------------BLUE/WHITE[SAME AS ABOVE]
CANMAX400DEI
WIRE 05, BLACK/WHITE, KEYSENSE----------------------------------------------BLUE/BLACK
WIRE 13, YELLOW/BLACK, CODE--------------------------------------------------BLUE
WIRE 14, VIOLET/WHITE, TXCT----------------------------------------------------GREEN
WIRE 16, GREY, AUTO LIGHT (RIGHT SIDE)-------------------------------------NOT SURE
WIRE 20, GREY/BLACK, AUTO LIGHT (LEFT SIDE)-----------------------------NOT SURE
valliyappan is offline   Reply With Quote
Old 01-17-2011, 09:30 AM   #2 (permalink)
Anyone? I'm mostly interested in the auto light wire color/location.
I got the lock/unlock.
Lock - Green (-)
Unlock - Blue/Yellow (-)
Old 01-30-2011, 06:46 PM   #3 (permalink)
View ryfly's Photo Gallery
auto light, your talking about the headlight switch correct?
ryfly is offline   Reply With Quote
Old 01-30-2011, 10:32 PM   #4 (permalink)
i believe so, the wiring which turns on the DRL and the headlight when it gets dark, from reading the "disabling DRL" on the 9thgencorolla forum im thinking it might be the red/white wire. But no one has yet to confirm this for me
