bad to worse. help! I need my car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2011, 05:59 PM   #1 (permalink)
View celica91's Photo Gallery
'05 corolla. IN extreme cold, it would idle rough and even stall before it is warmed up. No check engine light, but sounds like the intake gasket right? I even sprayed some carb cleaner around the manifold and idle got even worse. Got a new gasket, followed the instructions on the TSB for this issue, torqued bolts to spec. started it up. Now it idles rougher regardless of engine temp. and the check engine light is on, but i don't have a code reader, and the brake pedal is rock hard. I don't think I missed any hoses, so i don't know wrong. any thoughts?
celica91 is offline   Reply With Quote
Old 01-20-2011, 06:38 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
You have a vac hose loose, recheck all your connections.
mikered30 is offline   Reply With Quote
Old 01-21-2011, 07:06 AM   #3 (permalink)
View dorman68's Photo Gallery
I would go to Advance, AutoZone, or comparable retail chain. Most of these stores will scan your car free of charge.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-21-2011, 08:09 AM   #4 (permalink)
mikered30's Avatar
He doesnt have brakes.
Old 01-21-2011, 08:38 AM   #5 (permalink)
View extreme one's Photo Gallery
You need to pull the engine cover and double check all hoses and connectors. Remember if you disconnected the battery your idle will be rough for a while because the computer must "relearn" its values.
extreme one is offline   Reply With Quote
Old 02-01-2011, 11:10 PM   #6 (permalink)
AAO
View Elmacanite's Photo Gallery
As previously stated, definitely recheck all connections and hoses. Also, try disconnecting the negative battery terminal (COMPLETELY so that the metal contact is in NO WAY TOUCHING THE TERMINAL POST) for at least 15 minutes or so and that should reset the computer. Also, you may want to clean off your MAF sensor. Don't physically touch the filaments or whatever they're called, but you can spray it with carb cleaner or electric parts cleaner and be just fine. If you are unsure about what you should or should not use just ask someone that works at one of your local retail stores or simply call the store. Personally I just ordered a remanufactured MAF to try and fix a similar issue, and will be installing it tomorrow. Easy pop 'n swap procedure. Hope you get your car fixed soon, and best of luck.
Elmacanite is offline   Reply With Quote
