Oil change in automatic transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2011, 11:16 AM   #1 (permalink)
Marcin_CorollaLE's Avatar
View Marcin_CorollaLE's Photo Gallery
Hi!
How many litters do I need to change oil in automatic transmission in my Corolla 2005?
Do you recommend AMSOIL ATF?
Thanks!
Marcin
2005 Corolla LE
Marcin_CorollaLE is offline   Reply With Quote
Old 01-23-2011, 11:54 AM   #2 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
U can do a search for ATF fluid on the forum, but most say the drain and fill method needs about 4 quarts.
Use the Toyota ATF type IV fluid.
They run about $4 -$6, from dealer. call local dealers for best price.
If you have high mil, may consider unbolting ATF pan and changing out filter also.
matrixjim is offline   Reply With Quote
The Following User Says Thank You to matrixjim For This Useful Post:
Marcin_CorollaLE (01-24-2011)
Old 01-23-2011, 02:41 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
4 quarts (US) is what you need to buy for a single drain and refill but usually takes 3.2 quarts.. If you want to do a cooler line change you will need about 8 quarts. It is wasteful to mix Amsoil or any synthetic fluid for a single drain and refill. Not sure if you cant get T-IV in Poland from the dealer. If you want a recommendation on synethic fluid I suggest Redline D4, but buy what ever is cheaper. Mobil 1 makes a syn fluid too, make sure you get the kind that is T-IV compatible.
I noticed that the regular T-IV had poor shifting in pretty cold weather, especially in negative temps (F) not sure how cold it gets there. D4 had a noticeable change in shifting in the auto tranny. It worked so well I put it in my power steering reservoir.
mikered30 is offline   Reply With Quote
The Following User Says Thank You to mikered30 For This Useful Post:
Old 01-26-2011, 01:34 PM   #4 (permalink)
OK, so I will buy 4 quarts of synthetic oil but what happened when I mix new oil with old ? I mean I 'he got now Toyota oil ATF T-IV - I think is not synthetic fluid...
Marcin
2005 Corolla LE
Old 01-26-2011, 02:50 PM   #5 (permalink)
mikered30's Avatar
Is this a 9th gen US corolla or something else? It looks like a 9thgen in your pic and you said it is an LE.
Old 01-26-2011, 02:54 PM   #6 (permalink)
Exactly, it is.
Marcin
2005 Corolla LE
Old 01-26-2011, 06:45 PM   #7 (permalink)
mikered30's Avatar
When you mix the syn fluid with the old fluid, that is ok, but only doing a single drain and refill gets you only 41% of the fluid replenished. You would have to do 5 drain and refills to get close to 100% of the fluid replenished as the torque converter cannot be drained. A cooler line flush is more economical. T-IV is not a syn fluid. Make sure the fluid you get is compatible with T-IV.
Old 02-08-2011, 04:51 AM   #8 (permalink)
What do you think about "dynamic" method of fluid change - all fluid will be replace. Is it good idea?
Marcin
2005 Corolla LE
Tags
oil change
