When you turn the ignition key to ON before starting the car, the "Check engine" light is supposed to come on for a couple of seconds , and then go off, indicating that the engine computer is powered on. If the "CEL" does not come with the ignition ON, it's possible that there is no power coming to the engine computer (e.g, due to a broken wire, faulty relay, burnt fuse, etc.) or that there is a problem with the engine computer itself.
It's possible the wiring to the ECU is loose or faulty since you have the ECU recently replaced. Or the replacement ECU could be bad. In case you didn't know, the ECU is located under the dash behind the glove box.
