Weak Sauce suspension on my '04 LE - any upgrade suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2011, 09:32 PM   #1 (permalink)
View jzalk3metsfan13's Photo Gallery
Hi everyone.
I have a 2004 Corolla LE, and whenever I am hauling a decent amount of weight, or if someone larger than a child is sitting in the back seat, the car sags like crazy. This looks quite poor, especially with the 17" wheels I put on a few weeks ago. Does anyone have any suspension upgrade suggestions that will address this issue?
My biggest concern with aftermarket suspension products is sacrificing ride comfort. But I am willing to forego some comfort if it will solve my problem.
I was looking at Eibach's Pro-kit lowering springs, which claim to not sacrifice ride comfort. I also like that the drop on them is only around 1 inch, as opposed to the more agressive drop of 1.8 on the H&R application. But I cannot figure out from anywhere if they will help my problem.
Also, if I lower the car, will I have alignment issues?
Thanks for looking!
jzalk3metsfan13 is offline   Reply With Quote
Old 01-29-2011, 10:58 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
I have the eibach pro kit on my corolla right now, I really love the way it looks lowered, the wheels fit so much better in the wells. they are stiffer than stock but are not really UNcomfortable, it's just something to get used to. with the small amount that they eibachs lower you there really is not much effective alignment change, a bit more negative camber but nothing to cause any problems. if it does end up bothering you the parts you'll need (or a shop will need) to adjust camber are fairly cheap. a pair of camber bolts and alignment shims from rock auto or something, they're pretty cheap on there.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 01-29-2011, 11:07 PM   #3 (permalink)
Do they help the car from sagging with people in the back seat?
Old 01-29-2011, 11:09 PM   #4 (permalink)
Also, do you run with the stock KYB struts?
Old 01-30-2011, 09:38 AM   #5 (permalink)
on full afterburner
Gameroom cash: $1345697
I wouldn't lower the car if you're going to be carrying around a child in the backseat. Granted, most lowering springs use progressive rates which emphasize comfort over performance, but you'll still notice a firmer ride compared to stock. However, in this case, I would just recommend leaving the OEM springs in and upgrading the struts to Bilstein Heavy Duty.
Old 01-30-2011, 02:10 PM   #6 (permalink)
I don't have any kids, I was just using that as an exaggeration as to how badly my car sags with any kind of weight back there. Thanks for all of your help, phatroyale and TRD!
Will the Bilstein's have about an equal effect on ride comfort as the Eibach springs? If I upgrade one part of the suspension, will it cause problems to the stock components that remain? Should I just go for broke and get a coilover kit?
The car my Corolla protects from everyday use
Old 01-31-2011, 12:06 AM   #7 (permalink)
I have stock shocks with my eibach springs. I've only been outside of my car a handful of times while there are people in the back seats, but I once had 3 adults in the back (combined weight of at least 500 lbs) and the the top of the tires were just level with the top of the wheel well arch.
Im pretty sure that just upgrading shocks and leaving springs stock wont help with sagging, springs are responsible for ride height, not the shocks. but a combo of those bilstein HD's and some eibachs would most definitely help your problem i think.
Tags
coilovers, eibach, ride comfort, springs, suspension
