Heater issues. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2011, 05:17 PM   #1 (permalink)
View Colo.TJ's Photo Gallery
Heater issues.
Did a search but my searchfu isn't working very well.
2007 Corolla S.
Heater does not want to change from vent location. It blows at all power levels. It blows heat. It will not move from vent to defrost or feet when selector changed.
The selector appears to be fly by wire not directly connected to the dial. True?
Possibly a fuse?
Colo.TJ is offline   Reply With Quote
Old 02-01-2011, 05:48 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
You will have to pull out the HVAC panel and check the cables.
mikered30 is offline   Reply With Quote
Old 02-01-2011, 07:10 PM   #3 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
the temp dial and vent selector are cable actuated, and I think the power level (middle dial) is electronic if I'm not mistaken. you'll have take the HVAC register out to check the dial-end of the cables, but if those are good then checking the other ends can be a PITA. the temp cable can be accessed by removing the center armrest section but to get to the vent selector cable you may have to pop the upper dash off which can get a bit overwhelming.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
