New strange noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2011, 02:08 PM   #1 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
New strange noise
I have a 2005 LE with roughly 94,000 miles on it.
The past few mornings when cold the following happens:
Going uphill at roughly 40MPH under light/medium throttle (not enough to downshift)
There is excessive vibration from under the hood and a raspy noise...almost sounds like metal and rubber grinding. Giving it more throttle increases the intensity of the noise. It sound like it's coming from the right half of the engine bay. Once the car is warmed up the most I'll get is a slight vibration.
Any ideas?
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 02-03-2011, 04:23 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Motor mounts or heat shield.
mikered30 is offline   Reply With Quote
Old 02-04-2011, 06:34 PM   #3 (permalink)
View aspen007's Photo Gallery
I agree with Mikered30 that you should check your heat shield covering the exhaust manifold and oxygen sensor. It's at the back of the engine compartment between the engine's plastic cover and the firewall. To see if it is the shield, remove or loosed the four 12mm bolts holding the shield and take the car for a drive. If the sound is gone, you know that's the source. Replace/tighten the bolts and you should be good to go.
I recently had a strange metalic vibration sound during acceleration that was driving me crazy. Only by chance I found out it was the heat shield when I removed the shield to replace the oxygen sensor. After replacing the shield the sound was gone.
Good luck.
aspen007 is offline   Reply With Quote
Old 02-04-2011, 10:32 PM   #4 (permalink)
I still have to take the car in to have the engine computer replaced. My car is still under the platinum extra care warranty. Would the heat shield be included under that? If I can, at least while I am already there, tell the dealer to figure it out, I would much rather do that.
I don't think it's a mount, as it doesn't make the noise all the time, but the heat shield would make sense.
I also considered the belt tensioner, which is original and chirps slightly even with a new belt (that's on my list for warranty replacement when the computer is done). Maybe I'll get lucky and that will be the source of the chirp AND the other noise...not that I'm ever lucky...
Old 02-05-2011, 06:02 AM   #5 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
Any ideas?
does it sound like marbles in a container? is it on the passenger side?
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 02-09-2011, 06:44 AM   #6 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Hey Woody - mine has a sound that could be described that way, I guess (hard to use words to describe sounds, sometimes...) - seems to be coming outside of the cabin towards the passenger side, I only hear it @ mid-40s mph, occasionally when just pulling away (1 - 3 mph, maybe). Doesn't matter what gear I'm in, and the sound doesn't change between, say, 43 to 48 mph and doesn't change whether I'm steady speed or accelerating. Hmmmmmm....
PhantomS is offline   Reply With Quote
