using a non-transponder key - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2011, 09:11 PM   #1 (permalink)
View sjbro's Photo Gallery
I have a 2007 Corolla and would like to have a non-transponder key made to keep in my wallet in case I lock my keys in the car.
I have been told that if I were to inadvertently use a non-transponder key to try and start the Corolla that it would cause problems only a dealer could fix.
Please tell me that the only problem using a non-transponder key is that it will simply just not start the engine.
Thanks much for any help.
sjbro is offline   Reply With Quote
Old 02-03-2011, 09:31 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $255850
View Tech1984's Photo Gallery
Ok, I will please tell you it will not cause any problems and will simply not start the car.
It will set a code (p2799) unmatched key code, but you will never see that unless you were looking at a scanner.
So go ahead. You have a good idea there.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 02-03-2011, 09:35 PM   #3 (permalink)
Thanks Tech1984. I feel better already!
Old 02-05-2011, 01:18 PM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
Agreed. You won't have any problems at all.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
sjbro (02-05-2011)
