2005 Corolla-headlamp and chassis wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2011, 06:19 PM   #1 (permalink)
View jakesmom's Photo Gallery
I recently purchased my Corolla. I love it, but I'm having some electrical issues. The previous owner installed HID headlamps on the low beams. My battery kept dying and a friend told me to check it out online. I purchased the parts to put standard bulbs back, but the previous owner cut off the socket and rewired. Then I purchased a new socket. On the socket 85813/9006 both wires are the same color, so I'm unsure which wires to splice back together. Also, clock comes on intermittently. Airbag passenger light goes off when I turn the headlights on. Daytime running lights are also disabled. If any of this sounds familiar or you just know which wires on the socket go where, I would really appreciate any advice. Thanks in advance. Have a great Toyota day!!
jakesmom is offline   Reply With Quote
Old 02-13-2011, 10:14 AM   #2 (permalink)
Adama's Avatar
View Adama's Photo Gallery
I would first get you battery tested to make sure that its good, Autozone can do it for free. Once the battery is good, then I would check the HID to see if they are wired correctly. Most HID kits are plug and play, requiring no cutting/splicing of the wires. The daytime running lights (DRL) have to be disabled to run HID’s.
Repairing Daytime running Lights. First locate the “Relay Assy. Running Light”. This is located under the dash on the steering column. There are two ways to disable the DRL.
1. Cutting the Yellow wire and grounding the wire coming out of the relay.
2. Cutting the Red with White stripe wire (pin 12).
Depending on which wire was cut, it’s just a matter of reconnecting the cut wires unless the previous owner did something else and really messed things up.
Headlights. I like the advantage of HID’s but if you want to go back to stock, the low beam headlight wire it like this:
The top wire is Red with a Black stripe and the bottom wire is Red.
The Clock. A lot of corolla owners who have this problem will remove the clock and disassemble it to get access to the circuit board. Then take a soldering iron and heat the solder joints to make a better connection. If this fails, replace the clock.
I’m not sure about the air bag light but I do have the factory shop manual and wiring diagram for a 2004 corolla if you would like a copy. Good Luck.
H&R Race Springs / 09 Xrs Rims / TRD F & R Sway Bar / TRD FSB / Alutec RSB
Avic Z3
/ Tc Center Armrest / Tc HomeLink Mirror / Valentine 1 / ScanGauge II
Adama is offline   Reply With Quote
