Originally Posted by W6e6s6W
P0420 is a catalytic converter code.
So after you replace the cat, it should run alot better and not throw that code.
If it was an intake manifold gasket leak it would be a P0171 (System Bank 1 Too Lean)
agreed.
catalytic converter OR possibly the downstream O2 sensor (the one attached to the cat)
P0420 is a catalytic converter efficiency code. in many cases it's not the cat, but in fact the downstream O2 sensor gone bad.
the brain compares readings from the upstream O2 sensor and downstream O2 sensor and if the downstream is showing high CO the brain will throw the code.
2005 corolla .. so it could be the cat. however, the O2 is much cheaper. so start there and then replace the cat if a new O2 didnt solve the issue.
