Hi, my first post here.
My wife has a 2005 Corolla S I got her new summer 2004, I change the oil sometimes, sometimes have her take it in when I'm to busy at work HVAC tech.
Anyways, the car is far overdue for a coolant flush and change.
I think it's green standard coolant, but the manual says Toyota Extended life coolant.
I'm sorry, but I'm not buying coolant from the Toyota dealer, I have had good luck with Prestone on other cars.
What do you think?
I have hard water so I will use bottles of distilled water to do a gentle flush, instead of the garden hose.
Drain it, refill with just distilled water, drive it around and get temp up with heat on hot, then drain again, repeat until looking clean.
Then add new antifreeze.
Car has never overheated, this is just a maintenance as it has 110K on it.
