Originally Posted by superpaul3000
I just kept the regular lights on all the time to avoid that but from what I hear you can just unplug some fuse to disable DRL.
Unpluging or pulling a fuse will not disable the DRL. There are two ways to disable the DRL.
First locate the “Relay Assy. Running Light”. This is located under the dash on the steering column.
1. Cutting the Yellow wire and grounding the wire coming out of the relay. This is hit & miss as it didn't work with some corolla's
2. Cutting the Red with White stripe wire (pin 12). This is the easiest and make sure you cut it a couple inches away from the relay.
Use a good quality HID and not some ebay crap that is hit or miss. I would recommend
DDM as a fair price HID with a lifetime warranty and if you dont mind spending a little extra, go with their Slim Line Ballast. They are out of the slims now but will be restocked soon. I run their 55watt 6000K kit (over 2 years and it's plug & play) in both low beams and fogs and they give a nice white light and have driven behind CHP cars and have had no problems.
