engine revs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2011, 11:45 AM   #1 (permalink)
View jakeyseven's Photo Gallery
engine revs
just out of curiosity, when we say engine revs at 2000 for example , is it the crankshaft spinning at that speed or are the pistons moving at that speed
jakeyseven is offline   Reply With Quote
Old 02-27-2011, 01:05 PM   #2 (permalink)
View dagm182's Photo Gallery
Revolutions per minute (abbreviated rpm, RPM, r/min, or r·min−1) is a unit of frequency of rotation: the number of full rotations completed in one minute around a fixed axis. It is used as a measure of rotational speed of a mechanical component
dagm182 is offline   Reply With Quote
Old 02-27-2011, 01:39 PM   #3 (permalink)
what i mean is when the engine is turning , for example 2000 revs , is it the pistons moving up and down at that speed or is it the crankshaft moving at that speed
Old 02-27-2011, 06:27 PM   #4 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
No piston speed is completely different. Piston speeds are much higher than what the rpms are. They are measured in feet per minute and not revolutions per minute. Piston movement is one of the pre-requisites for the engine to complete its's revolution.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 02-28-2011, 07:53 AM   #5 (permalink)
View olbus's Photo Gallery
Not sure of your question, but each piston moves up and down with each rotation of the crank. It takes two complete revolutions of the crankshaft for one firing in a 4 cycle engine, so each piston is firing at 1/2 the rpm of the crankshaft. Crankshaft at 2000, each piston firing 1000 times.
olbus is offline   Reply With Quote
