Rear Speaker Adapters - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2011, 02:04 PM   #1 (permalink)
New 2 Toyota
View Stefan2k's Photo Gallery
Does anyone know of a company that makes adapters for the rear 6x9's in a 2007 Corolla S? i made the last pair out of wood but i would like something cleaner, better, that wont crack!
Stefan2k is offline   Reply With Quote
Old 03-01-2011, 08:01 PM   #2 (permalink)
Ohiowa's Avatar
View Ohiowa's Photo Gallery
According to Crutchfield, mounting aftermarket 6x9s takes drilling new mounting holes. Poking around online a while back, I read a guy's blog about how he mounted 6x9s in his and all it took was an afternoon of taking the rear deck apart and drilling screw holes for the new speakers.
Doesn't sound terribly complicated, as long as you can lay in your trunk to drill the new holes.
1989 Toyota Camry base 5spd (retired at 206,000mi)
2000 Saturn SL2 5spd
2004 Pontiac Grand Am SE1 V6 (totaled due to a rear-end collision)
2003 Toyota Corolla LE
Ohiowa is offline   Reply With Quote
Old 03-01-2011, 08:07 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
http://www.net4free.org/Other/nshahz...rspeakers.html
mikered30 is offline   Reply With Quote
Old 03-01-2011, 08:17 PM   #4 (permalink)
View sgtpepper868's Photo Gallery
Originally Posted by mikered30 View Post
nice write up ... except that foo needs to get a soldering iron! crimps + wire twisties = ghe-tto
sgtpepper868 is offline   Reply With Quote
Old 03-01-2011, 08:18 PM   #5 (permalink)
Ohiowa's Avatar
@mikered30 Thanks, that's the page I remember.
One thing worth noting is that you should avoid using wire nuts as the creator of that page did. Generally an unreliable way to connect wires. Most installation parts manufacturers will make a speaker adapter plug that you can either solder or crimp so you won't have to cut off the factory plug ends. Much cleaner and easier to undo if you decide to sell the car and put the factory speakers back in.
Old 03-01-2011, 08:28 PM   #6 (permalink)
Ohiowa's Avatar
Reading some of this guy's other tutorials at http://www.net4free.org/Other/nshahzad/ ...
He's nothing if not creative, but (whenever he wrote these) he needed a little technical refinement.
Old 03-01-2011, 09:10 PM   #7 (permalink)
New 2 Toyota
Old 03-01-2011, 09:15 PM   #8 (permalink)
New 2 Toyota
Thanks for the reply, but in my corolla a after market 6x9 will have gaps around it if you just drill some holes. I dont want the gaps! Like I said I made a template the first time I installed x9's but it was made of wood and cracked, I was looking for something thinner and more durable than wood. I guess i'll be off to home depot to get some sheet metal and cutting gear.
Old 03-01-2011, 09:17 PM   #9 (permalink)
Ohiowa's Avatar
If you mount it solidly to the newly-drilled holes, gaps won't matter.
