Weird Rattle in Passenger door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2011, 09:32 PM   #1 (permalink)
View Corcel's Photo Gallery
happens just as door closes, kind of sounds like one of those coil like door stops in houses, you know the ones that sort of look like a tightly wound spring. Window works fine, just started all of a sudden???
Corcel is offline   Reply With Quote
Old 03-03-2011, 12:39 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
I'd hit the hinges and the door arm with some white lithium spray or similar. Sounds like the original lubrication has dried up and/or you got some debris stuck in there, causing that loud creaking noise.
