Just got my new brake rotors front. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2011, 01:25 PM   #1 (permalink)
View lnarreola1's Photo Gallery
Hi guys i just got new brake rotors for 2004 corolla type-s, was wondering if its easy changing the rotors or hard?or is like any other brake job thanks.
lnarreola1 is offline   Reply With Quote
Old 03-09-2011, 03:15 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
just like any other car
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 03-09-2011, 03:36 PM   #3 (permalink)
Ok thank you, also i want to replace my serpintine belt and i got the goodyear gatorback one, whats the easiest way to loosen the bolt and putting back on the belt thanks.
Old 03-09-2011, 06:02 PM   #4 (permalink)
Raddman04's Avatar
View Raddman04's Photo Gallery
USA
Get a long 17mm wrench and pull towards the front of the engine(as shown) to relieve tension to remove and replace the belt, this is a diagram for cars with AC....One person can do it but it's easier and less dangerous doing it with two especially putting it back on!
Raddman04 is offline   Reply With Quote
The Following User Says Thank You to Raddman04 For This Useful Post:
Raddman (03-12-2011)
Old 03-10-2011, 04:54 PM   #5 (permalink)
Gameroom cash: $172005
View bennor's Photo Gallery
There's a big old thread about changing the serpentine belt on an 05 a few posts below yours... And it's also in the sticky Official 9th Gen Corolla FAQ - List of DIYs too...
Process should be the same. You do not loosen any bolts, put the socket/breaker bar on the "fake" nut on the tensioner assembly (shown in the post above) and apply pressure to pull the bar towards you or downwards depending on how you put the socket/breaker bar on the nut. Slip the belt off the alternator pulley then off the rest of the pulleys. Reverse the procedure and finally slip the new belt back over the alternator pulley. Takes about 10 minutes for one person to change out the belt if you have all the tools.
bennor is offline   Reply With Quote
Old 03-12-2011, 04:30 PM   #6 (permalink)
Is there an easier way to get the bolt loose?
Old 03-12-2011, 04:48 PM   #7 (permalink)
You do not "loosen" the tensioner bolt if replacing the serpentine belt. If you look at the image above you will see that you attach the socket wrench/breaker bar to a "fake nut" (I don't know what else to call it) above the tensioner bolt. Then pull the socket wrench/breaker bar towards the front of the engine bay and the tensioner assembly will move to release pressure on the belt so you can then slip the belt off the alternator pulley.
