HELP with taking off rusted rotor drives side<< - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2011, 12:07 AM   #1 (permalink)
View lnarreola1's Photo Gallery
Hi guys so i started changing the brakes on my wifes 04 toyota corolla type-s. The passengers side was easy took rotor off was little rusted so with a few hits the rotor came out, i then go to the drivers side and hit the rotor inside and from the outside wont BUDGE<<<what can i do to take it off please..its a pain in the butt to me rite now..
lnarreola1 is offline   Reply With Quote
Old 03-13-2011, 12:25 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
If the rotor have two little holes beside the lug holes on the rotors, you can screw in two bolt to slowing push the rotor off the hub. (Not sure what size bolts) But I would just spray some WD-40 between the studs and lug holes, then take a mallet and hammer the side and the rotor hat. Tapping the rotor with a metal hammer around the hat helps break up the rust . You just have to keep beating it until it comes off. It's a pain.
Also, screw on one lug nut partly on the stud to prevent the rotor from fly off when it break free.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 03-13-2011, 12:37 AM   #3 (permalink)
Great, yeah i was thinking on using two bolts but dont know the size tho..i hate it when they get rusted like that and freeze up. What kind of rotor lube can i use so it wont stick on there anymore?thanks
Old 03-13-2011, 12:53 AM   #4 (permalink)
Yuko's Avatar
I think the bolts are 8mm x 1.25. After the rotors are off, I would just dap a bit of anti-seize between the rotor and hub surface, Don't get any on the studs as it can cause you to overtighten the lugs nuts.
Old 03-13-2011, 06:43 PM   #5 (permalink)
OK, so i got the drivers side off with using two bolts, it was a paint but its off. I installed new semi metallic pads and oem rotors feels better.
