Noise on my corolla when cold..help please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 10:59 PM   #1 (permalink)
View 2jzrps13's Photo Gallery
Hi every one i have a 9th gen corolla and when i turn it on it makes a knocking noise but goes away after warming up...any ideas? thanks!
2jzrps13 is offline   Reply With Quote
Old 03-22-2011, 12:58 AM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
What's your mileage? You hear it only when driving before it's warmed up? Piston slap noise when engine is still cold is common with the 1ZZ-FE, as does mine.
invader is offline   Reply With Quote
Old 03-22-2011, 05:09 AM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Perhaps the belt tensioner.
mikered30 is offline   Reply With Quote
Old 03-22-2011, 07:53 AM   #4 (permalink)
Ohiowa's Avatar
View Ohiowa's Photo Gallery
With 98,000 on mine, it's very noticeable when the overnight temp is below 50ish.
Goes away once the car is warmed up.
Sounds like it's coming from behind the intake manifold.
1989 Toyota Camry base 5spd (retired at 206,000mi)
2000 Saturn SL2 5spd
2004 Pontiac Grand Am SE1 V6 (totaled due to a rear-end collision)
2003 Toyota Corolla LE
Ohiowa is offline   Reply With Quote
Old 03-22-2011, 09:24 AM   #5 (permalink)
mikered30's Avatar
if the noise is behind the intake manifold then that are your injectors clicking and that is normal.
Old 03-22-2011, 12:00 PM   #6 (permalink)
i got 158,254 miles on mine and is more like a ticking noise but after i drive it for about 5 mins and it gets warmed up it goes away... thanks everyone .
Old 03-23-2011, 12:17 PM   #7 (permalink)
Ohiowa's Avatar
Mine is more a heavy know sound than a tick. Tends to quiet down somewhat with new engine oil, but returns after 3-4000 miles.
At first I was terrified that I'd need a new engine (or at least a rebuild), but now I'm just making sure I change the oil a little more frequently.
Old 03-24-2011, 03:30 AM   #8 (permalink)
i have heard around that the timing chain tentioner often makes a ticking noise
Old 03-24-2011, 04:45 AM   #9 (permalink)
No, it's actually the serpentine belt tensioner that can get noisy, especially the original INA one.
Old 03-24-2011, 09:19 AM   #10 (permalink)
Oh what a feeling...
Josh.Chaos's Avatar
View Josh.Chaos's Photo Gallery
Hey, im new to Tn, but not corolla forums, I have had the same problem. I had a clinking sound during cold starts, and a knock when I put it into reverse before she warmed up. I have fixed that problem, through trial and error. I replaced the rubber exhaust gasket between the header and midpipe, and bent my heatshield a bit so it would stop knocking against my under carriage. At least thats what fixed my problem. The 1zz does idle awfully high on a cold start, it makes stuff rattle around quite a bit.
Josh.Chaos is offline   Reply With Quote
Old 03-24-2011, 09:42 AM   #11 (permalink)
Exhaust manifold flange gasket is not mader of rubber, but Fel-Pro # 61106 is a good upgrade with its solid soft metal core where the OEM tends to burn out.
http://www.rockauto.com/catalog/x,ca...,parttype,5836
Old 03-28-2011, 03:03 AM   #12 (permalink)
thanks guys i will try and see if it goes away with what you have told me... again thanks very much.
