I easily replace all the power steering fluid without a suction pump... Jack up the front, remove front left wheel, unhook lower PS hose on rack+pinion and drain in a bucket. Attach a hose (~1/2" ID) to rack+pinion fitting, with the other end of hose into bucket. Remove small hose in front of PS fluid reservoir which is now empty (1st hose you drained), and plug the hole. Start filling reservoir with new fluid which flows through pump and rack+pinion, as old fluid comes out attached hose. Keep filling reservoir while turning steering wheel all the way back and forth a few times. Reinstall bottom hose when fluid comes out clean and red. Remove plug and quickly rehook hose on reservoir, then fill up to max cold line. Turn steering all the way both sides a couple times and keep refilling to bleed air out. It takes almost a quart.
