Flush brake and power steering fluid. Drain and replace tranny fluid. How are your brakes? PCV valve should be replaced. Did you get the ECU inspected? Coolant is overdue so change that.
I got my intake manifold gasket replaced maybe 20,000 miles ago? I've just started learning what I can from reading and talking to friends about engines and stuff so I'm not real familar with what everything does
but I've been trying to find stuff I can do myself. I either got my coolant or transmission fluid changed when I got the intake manifold replaced Ill have to call and check which one. My brakes are fairly new but I probably need to give them a look with all the driving I do. Should I worry about shocks, struts, tire rods? Thanks for all the help again
