Thanks for the vid. changed them and all is well. I went ahead and went with the NGK 5464. $7.09 + tax each!!!
Figured I would go ahead an put it in writing for future reference.
Simple steps
1> disconnect battery
2> remove plastic engine cover
3> disconnect all coil packs
4> remove pack screw
5> remove screw that affixes the connector wiring harness cover
6> remove packs
7> remove plugs
8> insert and slightly tighten new plugs
9> torque plugs 18ft lbs
10> reinsert the packs
11> reinsert pack screws and torque 9ft lbs
12> reattach wiring harness cover screw
13> reconnect coil packs connectors
14> reattach plastic engine cover
15> reconnect battery, done*
* please note that when I went to start my car the first time it did not start. It did start on the second try. When I first started driving the idle was a little low. I drove a mile or so and stopped, the idle was low, about 650 or 700rpm, after sitting there for a minute the idle gradually worked its way up to the norm of 900rpm that my baby idles at. Then I drove about drove about 8 miles or so and everything is running great. I don't know if the car's computer needed some time, and engine cycles, to make adjustments for the new plugs, so that the car would run normal, or not? Either way, don't get discouraged if she doesn't seem right at first. The issues seem to self-correct.
