trans fluid bleeding off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2011, 10:24 AM   #1 (permalink)
View lewisschultz's Photo Gallery
USA trans fluid bleeding off
I have a 05 corolla with 40,000 mile on it and a auto trans. The question is when engine is warm and you have to come to a quick stop the trans squells ,sounds like its bleeding pressure off then it stops. when braking normally doesnt do it. its done it since new. fluid has been changed with correct fluid
took it in and could nt find any wrong. Seem to be doing it more now.
lewisschultz is offline   Reply With Quote
Old 04-07-2011, 10:55 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
how do you figure it to be the transmission? does your car have ABS?
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 04-08-2011, 07:40 AM   #3 (permalink)
View ToyoLuv's Photo Gallery
You're going to have to explain yourself a little better. Your post is very confusing. You say it happens when you "have to come to a quick stop", yet "when braking normally doesn't do it??? Do your quick stops not involving braking?
ToyoLuv is offline   Reply With Quote
Old 04-08-2011, 08:44 AM   #4 (permalink)
Yes,when traffic light changes to red and I need to stop quickly and the engine is warm and it's say 90 degrees outside it will squeal for 5-10 seconds after a complete stop.After the stop I shift it into neutral ,the squeal and pitch of noise increases untill it stops. engine still running with no noises. When it is winter time I dont hear it at all. This has been going on since it was new.
Old 04-08-2011, 08:48 AM   #5 (permalink)
the noise comes from the trans area when i do it in a parking lot and open the hood. it continues for 5-10 sec even after the brakes are released. yes it has abs.
Old 04-08-2011, 10:59 AM   #6 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Does it Do it do it in reverse? What fluid was used last time you refilled it. I guess you don't see any fluid coming out the vent? Fluid level ok?
mikered30 is offline   Reply With Quote
Old 04-08-2011, 02:27 PM   #7 (permalink)
hmm, if at all possible, would you be able to get a video of it doing it? that might help tremendously if we were to actually see/hear what's going on. record in the parking lot scenario and also in real world driving if you can.
Old 04-08-2011, 08:55 PM   #8 (permalink)
Originally Posted by trdspeed140 View Post
hmm, if at all possible, would you be able to get a video of it doing it? That might help tremendously if we were to actually see/hear what's going on. Record in the parking lot scenario and also in real world driving if you can.
i'll see if i can and i'll try it in reverse also.
Old 04-08-2011, 08:57 PM   #9 (permalink)
Originally Posted by mikered30 View Post
does it do it do it in reverse? What fluid was used last time you refilled it. I guess you don't see any fluid coming out the vent? Fluid level ok?
i used toyota type 4 fluid no leaks and i'll try it in reverse and get back to you.
Old 04-08-2011, 11:44 PM   #10 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Is it worse with the A/C on? Are you on the original serpentine belt?
invader is offline   Reply With Quote
Old 04-09-2011, 07:44 AM   #11 (permalink)
it does it with the ac off and yes the belt has been replaced.
Old 04-11-2011, 10:17 AM   #12 (permalink)
it does it about 40 % of the time and yes it does it in reverse neutral and drive
