Power Steering Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2011, 11:51 AM   #1 (permalink)
2004 Toyota Corolla
View billisnice's Photo Gallery
I have a 2004 LE corolla. Toyota recommend their automatic transmission fluid(ATF) to replace the old power steering fluid. Is this correct? If so, how much do I need? Where is the drain?
Thanks.
billisnice is offline   Reply With Quote
Old 04-14-2011, 08:29 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
I use Amsoil synthetic ATF. It takes almost a quart:
http://www.woodsbrosracing.com/amsoil/atf.htm
They now make power steering specific fluid, but only in 16 oz bottles: http://www.woodsbrosracing.com/amsoil/psf.htm
Originally Posted by invader View Post
I easily replace all the power steering fluid without a suction pump... Jack up the front, remove front left wheel, unhook lower PS hose on rack+pinion and drain in a bucket. Attach a hose (~1/2" ID) to rack+pinion fitting, with the other end of hose into bucket. Remove small hose in front of PS fluid reservoir which is now empty (1st hose you drained), and plug the hole. Start filling reservoir with new fluid which flows through pump and rack+pinion, as old fluid comes out attached hose. Keep filling reservoir while turning steering wheel all the way back and forth a few times. Reinstall bottom hose when fluid comes out clean and red. Remove plug and quickly rehook hose on reservoir, then fill up to max cold line. Turn steering all the way both sides a couple times and keep refilling to bleed air out. It takes almost a quart.
invader is offline   Reply With Quote
