Toyota Corolla 2003 Rotor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2011, 07:30 PM   #1 (permalink)
View will319's Photo Gallery
USA Toyota Corolla 2003 Rotor
Hi, my name is Will. Actually I owned 3 different models of Toyota. One of them is Corolla needs to be repaired. I would like to replace the front rotors on Corolla 2003 installed with steel wheels. It is a Rotor that installed with the hub nut. How do I remove it from Hub? Any idea what size of hub nut?
I would be very much appreciated if you can let me know how can I replace it. Thank you.
will319 is offline   Reply With Quote
Old 04-15-2011, 09:23 PM   #2 (permalink)
Raddman04's Avatar
View Raddman04's Photo Gallery
USA
Originally Posted by will319 View Post
Hi,
I would like to replace the front rotors on Corolla 2003 installed with steel wheels. It is a one pc rotor that installed with the hub nut. How do I remove it from Hub? Any idea what size of hub nut?
You take your the brake caliper off by removing the two bolts holding it from the rear and it slides right off your lug bolts
Raddman04 is offline   Reply With Quote
Old 04-15-2011, 09:45 PM   #3 (permalink)
Thank you for the replied.
I did took out the brake caliper off by removing the two bolts holding it from the rear and I still couldn't remove the rotor. I tried hammer on the rotor and found out it installed with the hub nut. It is not like regular rotor just slides in and out. It tighten on the hub. Any idea!! If I have to remove from the hub can you let me know what size of the socket? Thank you.
Old 04-15-2011, 10:32 PM   #4 (permalink)
Raddman04's Avatar
I think you're confusing your front axle hub assembly with your rotor it might look like it's all one piece but the rotor hole slips over that flange on the hub assembly, it might be froze on, it would be better if you had a picture of it, I never took that nut off and my manual only gives a part number, but my guess is it might be a 23 mm..Just keep trying a fit from 19mm up till you get the right socket!
Old 04-15-2011, 10:40 PM   #5 (permalink)
Thank you again and the GREAT picture . I will try tomorrow and will let you know.
Old 04-15-2011, 10:53 PM   #6 (permalink)
Raddman04's Avatar
USA
Good luck my friend
Old 04-15-2011, 11:00 PM   #7 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
So you just want to replace your front brake rotors? No need to remove the axle nut. Your rotors are rusted on tight. I just broke the rotors loose by whacking them hard near the outer edge with the end of a 2X4 wood stud, or with a heavy sledge hammer.
Applying some high-heat anti-seize compound to your new rotors' seating surface on the back will prevent them from getting stuck on again.
invader is offline   Reply With Quote
Old 04-15-2011, 11:06 PM   #8 (permalink)
Thank you for replied. I will try tomorrow hope I can fix it
Old 04-15-2011, 11:10 PM   #9 (permalink)
You'll find that they're ridiculously hard to break loose... Don't be afraid to get in a rage and use well applied brutal force. Set your wheels straight, and let it sit against the steering lock with ignition key removed. You can also try rotating rotor 1/3 turn after trying for a while to hit it on different portions to work it loose. Hit it as close to the outer edge as possible. Locking the steering at a slightly turned position might give you a better angle.
Old 04-16-2011, 01:19 AM   #10 (permalink)
Gameroom cash: $199666
View jkg065's Photo Gallery
Thumbs up Removing front brake rotor
There are 2 bolt holes on the raised hat portion of your rotors. These are located between the wheel stud holes. You will need 2, 8 x 1.25mm bolts that are screwed into these holes. As they are tightened the bolts will push against the hub and the rotor will come free!
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is offline   Reply With Quote
Old 04-16-2011, 01:46 AM   #11 (permalink)
Will319's 2003, my 2004 and bro's 2005 Corolla don't have those threaded M8 x 1.25 bores on original front brake rotors.
Old 04-16-2011, 02:21 AM   #12 (permalink)
Remove rusted/seized rotors
Would this procedure work instead?
The Following User Says Thank You to jkg065 For This Useful Post:
silver04rollas (04-16-2011)
Old 04-16-2011, 02:47 AM   #13 (permalink)
Very nice method, yes. It is important to gradually tighten both sequentially to even out the load. Cool video..
Old 04-16-2011, 02:59 AM   #14 (permalink)
I'm just happy to have been able to pass this along.
invader (04-16-2011)
Old 04-16-2011, 01:48 PM   #15 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Nice video, jkg065.
Very informative.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
