Squeaky sound from engine bay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2011, 02:59 PM   #1 (permalink)
View Traderjoe's Photo Gallery
I have a 2005 Corolla with 47K miles on it.
When I'm parked at a red light (Transmission in Drive, brakes engaged, idling) I get this squeaky sound coming from the engine bay. If I'm in my driveway (transmission in park or neutral, doesn't matter if brakes are engaged or not), the squeaky sound is gone. I've replaced the belt on it already (it was cracking anyways), but the squeaky sound is still there. I've tried belt dressing to no avail.
What the heck is it?
Traderjoe is offline   Reply With Quote
Old 05-11-2011, 03:22 PM   #2 (permalink)
View prophase's Photo Gallery
I hate belt dressing and will never use it again, at one point it made the belt noise worse until it wore off.
Just an educated guess but maybe belt tensior.
Not sure if you used the Goodyear gatorback belt or not but if you did not, the new belt could start squealing pretty quickly again. This happens to my wifes 05 corolla. The goodyear belt has been on for quite some time and is only now starting to make some noise, or her tensioner is on the fritz.
05 Corolla LE
07 Subaru 2.5i wagon - modded
prophase is offline   Reply With Quote
Old 05-11-2011, 06:36 PM   #3 (permalink)
I don't think I got the Goodyear belt. It was the more expensive brand from O' Rilley's though. It was squealing before the belt change, and it's squealing after.
Belt tensioner? The belt is always in contact with the belt regardless of gear (it squeals only in Drive. Not in Neutral or Park). Is there something I'm missing?
Old 05-11-2011, 09:49 PM   #4 (permalink)
You do understand that a when the car is in drive or (D) if you have an auto (which I assume you do), the engine is under load, whether at a light idling or while driving. This load could be stressing the tensioner possibly or another pully on your engine.
When in nuetral or park and car is running, the engine idles freely with almost no load or stress on any of the engine components.
If your belt is really new and you're sure it's not the belt, could be belt tensioner or pully on one of the accessories possibly.
05 Corolla LE
Old 05-11-2011, 10:55 PM   #5 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Looks like a serpentine belt needs to be replaced.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 05-11-2011, 11:45 PM   #6 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Load on accessory belt and tensioner isn't higher in drive compared to neutral... It was squealing before, and still does with the new Gates belt from Oreilly's.
Could you get a sound clip of the said squeek from under the hood?
invader is offline   Reply With Quote
Old 05-12-2011, 08:14 AM   #7 (permalink)
Amber's Avatar
View Amber's Photo Gallery
What happens if you rev the engine a bit while in 'D' and holding the brakes? Does the frequency of the squeal stay the same, increase with engine speed, or go away?
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
Old 05-15-2011, 09:42 AM   #8 (permalink)
Oh what a feeling...
Josh.Chaos's Avatar
View Josh.Chaos's Photo Gallery
Check the tensioner, like they said... I had the same problem. I got a brand new tensioner from a friend who used to work the toyota parts dept, and I have been squeek free (with my gatorback), for about 25k miles...
Josh.Chaos is offline   Reply With Quote
Old 05-18-2011, 12:48 PM   #9 (permalink)
Okee Doke! I'll try replacing the tensioner and alternator pulley. Thanks!
One last thing. Is the engine under more load when in D (drive) than in Park? It's weird because in both Drive and Park, I rev to about 2000RPM and I only get squealing when in Drive. But the belt goes around the same components. What's the difference?
Old 05-18-2011, 06:38 PM   #10 (permalink)
Engine is under load through transmission in Drive, but not in Park. Load on serpentine belt is the same at 2000 rpm, whether it's in Drive or Park... What exactly is squealing or squeaking? Try to isolate the noise source.
