how to bypass neutral safety switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2011, 12:20 PM   #1 (permalink)
View Toyotaboy87's Photo Gallery
currently the only way to start my 2005 corolla S is with two wires from battery and starter to push button(roll start works as well). reason being is b/c i did auto>5spd transmission swap. i do not have a neutral safety switch nor do i know where the connector is for it. how can i bypass so i can use the oem ignition again?
thanks in advance
Toyotaboy87 is offline   Reply With Quote
Old 05-17-2011, 04:47 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
do you have a manual ECU/engine harness or are you still using the automatic ECU & harness? I'm still running the automatic ecu and harness on mine and I just had to cut and solder together a couple wires and it works just like normal.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 05-18-2011, 12:27 PM   #3 (permalink)
ecu and engine harness are from 5spd manual
Old 05-22-2011, 11:52 AM   #4 (permalink)
bump for help
Old 06-04-2011, 05:04 PM   #5 (permalink)
any suggestions?
