installing LEDs in dash/under etc. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2011, 11:26 PM   #1 (permalink)
View Brent1238's Photo Gallery
Anyone done modifications like this? I want to take it on myself, but I've never done electrical work. I don't want to end up blowing a fuse, wiring poorly so anyone who can give me any advice would be great. Thanks. If possible I wanted to hook it up so the lights would come on either when I flip a killswitch or when I open my doors.
Brent1238 is offline   Reply With Quote
Old 05-25-2011, 10:07 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
As long as you are talking about the under dash lamps and wiring them into a separate circuit on the fuse box, should be little to low risk to the rest of the electricals. If something should happen, it will just blow that fuse. Cutting and splicing the OEM wiring is always more risky that implementing a separate circuit. Lot of the OEM wiring is interconnected, making it sometimes tough to diagnose if something goes wrong. Also use proper wiring practices - seal all splices, use proper wire strippers, solder where possible, use internally coated heat shrink tubing for water tight seals, add cable support/strain relief where necessary, etc. Fortunately, most of this info can be researched online.
Now wiring them to come on with the doors - there are a couple of options. Not hard to wire up, but will require splicing into the existing wiring (dicey situation if you haven't done this before) or add a second momentary switch or separate switch just for the under dash lighting (drilling holes, run wiring, etc.) is less risky, but requires more work.
Most important tip - disconnect the negative battery terminal before you touch any wiring. Most common mistake I see is people cutting and splicing wiring when the battery is still hooked up. Only takes one hot wire to be shorted to ground to blow a fuse, or worse, burn up the wiring somewhere else, making that much harder to diagnose.
The Following User Says Thank You to fishexpo101 For This Useful Post:
Brent1238 (06-08-2011)
Old 06-30-2011, 01:34 PM   #3 (permalink)
Thanks for the info! I'll have to keep that in mind. I hate the interior lighting color in my '05 Corolla so I was trying to locate the LEDs also. I found them, but I have NO IDEA where to find replacements online. Can anyone help?! I took a few pictures of the bulb, but I can't figure out how to post them. I'll post them if someone tells me how to. Please help! Thanks.
