New here...E brake help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2011, 10:57 PM   #1 (permalink)
View brokecorolla's Photo Gallery
So I finally got the will to change the rear brakes myself...and now my e brake does not work. Every thing is hooked up except for the e cable on the pass side. It came off the braket and will not go back on. It does not appear that it is threaded thru the bracket. There is a u shaped ledge on the bracket that is was in. I am in dire need as I have to drive and dont even know if I should or not. BTW the brakes work fantastic just no e brake. Thanks for any and all help.
brokecorolla is offline   Reply With Quote
Old 06-10-2011, 02:15 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1001164
View humanoid's Photo Gallery
What year and what model Toyota do you have?
This is my sig.
humanoid is offline   Reply With Quote
Old 06-10-2011, 07:09 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $913427
iTrader Score: 59 reviews
to TN
What Humanoid said
Once we know what your driving, then maybe we can help find the answers you seek!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 06-10-2011, 10:02 AM   #4 (permalink)
E brake
Sorry. It is a 2005 corolla.
Old 06-10-2011, 10:18 AM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Thanks
I moved your thread to the 9th gen Corolla Forum. I bet there is a member here than can help answer your question.
98 Honda CRV
08 GMC Crew
Old 06-10-2011, 12:31 PM   #6 (permalink)
Thank you for your assistance. I was pretty tired last night and was having some difficulty getting things figured out.
Old 06-15-2011, 11:17 AM   #7 (permalink)
Gameroom cash: $103000
View shoujiliuzhijun's Photo Gallery
Do you have a picture showing what it is now?
Even after you put everything back on, you may still need to adjust the E-brake. I remember it should also be self-adjusting by backing up and stop.
If you are talking about this cable, it is retained to the other part by the spring on the cable. Use a plier to hold the spring away from the end of the cable, then remove or install the lever.
shoujiliuzhijun is offline   Reply With Quote
Old 06-16-2011, 11:37 AM   #8 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
after you do that ^^^, a few good hard stops going in reverse should automatically adjust the brakes, that is, unless you turned the star-wheel all the way back, then you'll want to manually adjust it through the little access hole on the back-side of the brake assembly (still do hard reverse stops after manually adjusting too just to be safe).
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
