If it's more than 90 degrees outside, then low side at 50 PSI is not too high. At least, that is what my chart shows. Anything over 55 PSI at that temperature or above is too high (according to the chart). Check an ambient temperature chart and look for the appropriate pressure at your ambient temperature just in front of the condenser. It's important to check the high side pressure as well. This will tell you if you have a problem with your expansion valve. As Mikered30 said, high side should be 200 - 250 PSI. Also, to get accurate guage readings, they should be done after 10 minutes of the system being engaged with the guages connected (although yours may not engage for that long, I understand). Also, FYI, if you want to replace your A/C relay it will cost you about $70 from Toyota, but if you use a Honda relay (which fits/works perfectly) it will only cost less than $10.
