help needed on rear brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2011, 02:32 PM   #1 (permalink)
View jakeyseven's Photo Gallery
hello . i am trying to perform a rear braske job, the one brake disc came off quite easy , but the other one is a right pain , i have spent two hours trying to get it offf.
i have looked in the manual and it states if it is hard to get brake disc off , take out middle consill and slacken off nuts , then pull out rubber gromet from disc and there should be a star shaped adjusment to allow to slacken off brake shoes . i can not see this defice at all and need help please
jakeyseven is offline   Reply With Quote
Old 06-18-2011, 09:35 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Rear brake shoes are in drums, not discs (rotors) like the front brakes... You can press out the drum with two metric bolts tightened in the threaded holes on flat outer surface.
invader is offline   Reply With Quote
The Following User Says Thank You to invader For This Useful Post:
jakeyseven (06-20-2011)
Old 06-18-2011, 09:42 PM   #3 (permalink)
You can use the spare tire screw in one hole then the other, and so on...
Old 06-18-2011, 09:54 PM   #4 (permalink)
Gameroom cash: $103000
View shoujiliuzhijun's Photo Gallery
You can screw bolt in the two holes. I remember M8 1.25 bolt is the one you need.
But I think the hardest part is one of the springs, extremely tight.
shoujiliuzhijun is offline   Reply With Quote
Old 06-18-2011, 10:16 PM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $532567
He is from the UK so probably has disk brakes in the rear.
mikered30 is offline   Reply With Quote
Old 06-20-2011, 10:11 AM   #6 (permalink)
cheers for your help. i had trouble getting the one disc off, as it came off it pulled the retaining clip off that holds the brake shoe. i put it back on , drove the car and suddenly a large squealing sound from the back , iremoved the disc and found that the retaining clip and the pin had totally disintergrated , so now i need to find a place that sells these. its hard to find anywhere
Old 06-20-2011, 10:32 AM   #7 (permalink)
Can you show a picture what it is now?
NAPA sells drum brake hardware kit, maybe you'll find what you need. Just make sure they do shipping outside USA.
