Help....cannot remove the 30 mm locked axle nut!
I need to change the CV half-shafts on my 2004 Corolla sedan with 5-spd transaxle. I got new ones from Rockauto. Started on LH side, but there is a 30 MM 12-point axle shaft nut, and it appears that I cannot budge it with 12 MM 1/2 in. socket because they used a staking tool to punch a little rectangular dimple on the nut to lock it. (I see there is a special tool I can get ---the socket and a special punch/levering tool, for 30.00.) But this looks like it is made to slide into the groove and then you bend the staked indent back outward to unlock the nut. On my car, however, the staked indent isn't in line with the groove in axle! It is on the threads, about 3/8 in. over from the groove! So even if I bought this tool, I would end up severely damaging the axle threads. I guess I have no choice but to just use one of my own flat-bladed punches and hit the front edge of the nut at the dimple enough to allow the nut to turn? This of course will render the old half-shaft unuseable again if I have the wrong part....so I will be sweating bullets that Rockauto has sent me the correct half-shaft!
I have already tried punching the front of the nut at the dimple a little, causing minor damage to the threads, but even after using mapp gas on the nut, and with breaker bar and cheater pipe, it still didn't turn!
it looks like I will have to completely destroy the nut, so does anyone know where I can get a new one? I checked Rockauto for this, they don't list it, and a google search didn't turn up a source. Maybe any 30 MM nut could be used with a lockwasher? One one of a type that can be cotter-pinned?
Also, I didn't find in my Haynes manual on the car where it states what lubricant is to be used in the manual transaxle. Anyone know?
