Transmission Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2011, 03:26 PM   #1 (permalink)
View cor06's Photo Gallery
Transmission Fluid
I have a 06 Corolla CE (45K miles). I bought it new and since then go to the dealership for regular oil and filter change that is recommended in the Service manual that comes with the car.
Water pump, Tensioner and Serpentine belt were changed under warranty during this time so I have a new belt anyway.
I was reading in this forum that several members have changed transmission fluid or recommended to change transmission fluid. This is not recommended ot mentioned in the Service manual from Toyota and the dealership never mentioned. Even the coolant change/flush is not mentioned.
So question is why should we change transmission fluid? or does this really help increase the engine life? The color of the transmission fluid looks OK.
Thanks
cor06 is offline   Reply With Quote
Old 06-29-2011, 08:53 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
not being mentioned in the owner's/service manual aside, do you think it could be a bad thing to change the fluid? no. new fluid trumps old fluid every time. old fluid can make the component, whatever it may be, run less efficiently.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 06-30-2011, 01:29 AM   #3 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Replace auto transmission fluid at every 72 months/60000 miles, manual tranny fluid at every 48 months/40000 miles, coolant at every 40000 miles, as recommended by Toyota in the "Recommended Maintenance" section of your Owner's Manual Supplement: "Warranty, Maintenance & Roadside Assistance Information for 2006 Models".
invader is offline   Reply With Quote
Old 07-01-2011, 12:00 AM   #4 (permalink)
View saskrider's Photo Gallery
Some drivers for whatever reason idle the vehicle for a long time, so a vehicle might have 50000miles but in reality it running like 75000miles, so it's better to be proactive and i prefer to change it before the suggested time/mileage, if something fail it will not be because of the fluid, also the color might look ok, but did you compare it to new fluid? i suggest to buy a liter of fluid at the dealer and compare color and odour and you might your mind....and if you do it you will save a lot of money
saskrider is offline   Reply With Quote
Old 07-01-2011, 11:02 AM   #5 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
Thanks
You probably just made a typo...but changing the tranny fluid would not have any effect on the Engine...........that being said if I was you I would swap out the fluid.....I think yours is Toyota type IV. 8 quarts would be <$50. dropping the pan is best but even pumping out the 7 quarts is very good also.....That fluid in your car is 6 years old.....
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
