Originally Posted by cachorros
what could be the rpm is not constant aftre the engine is started the rpm goes up down but very slighly is because the engine needs a tune up
do you know if the shop manual for a corolla 2004 could be use on corolla 2005
thanks for your help
You most likely have a vacuum leak at the intake manifold gasket, especially if you still have the original black one, which is visible where the manifold sits on the engine head. New revised gasket is orange, only about $8.00, and is pretty easy to replace.
2004 service manual mainly the same, apart from your drive-by-wire throttle body.
