I don't think sludge is a common issue with the 9th gen Corollas with reasonable maintenance intervals. Oil changes every 5-6k using mobil 1 should not cause any sludge issues, even using reg dino oil with a 5k interval should not cause sludge. I change my oil every 3-5k using dino oil depending when I remember or when it's convenient for me and have zero sludge issues. If I were you I would pull the valve cover and check for sludge just to put my mind at ease, also check your pcv valve, if it appears gummed up or stuck I would replace it.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
