Changing Trans Fluid Procedure? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2011, 10:58 AM   #1 (permalink)
View Rockosmith's Photo Gallery
Is it difficult to change the trans fluid yourself? 05 Corolla with 108K. Is there a guide or steps taken? Thanks.
Rockosmith is offline   Reply With Quote
Old 07-13-2011, 11:07 AM   #2 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
the easiest way is to just drain it and refill it. you won't get all of it out, but it's enough for a change. always check fluid level when car is still warm.
don't know about the corolla, but my wife's solara required a 10mm hex head socket for the transmission drain plug. it's pretty easy to locate, it's right near the oil pan.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is online now   Reply With Quote
The Following User Says Thank You to nitronate33 For This Useful Post:
Rockosmith (07-13-2011)
Old 07-13-2011, 11:10 AM   #3 (permalink)
Do you use any brand of fluid?
Old 07-13-2011, 11:15 AM   #4 (permalink)
it's more expensive, but it's better to go with a synthetic ATF and it's perfectly ok to mix that with whatever is in there now.
all you have to do is make sure the ATF meets Toyota's T-IV spec (read the label on the back of the bottle). most ATF's will meet this spec. i used Mobil 1 Synthetic ATF for my wife's toyota.
one more thing, i'm assuming you have an automatic transmission, correct?
Old 07-13-2011, 11:27 AM   #5 (permalink)
Offical TN Vendor
View AutoPartsWAY's Photo Gallery
You may need a filter
2005 Toyota Corolla Auto Transmission Filter
Possibly Drain Plug Seal also
AutoPartsWAY is offline   Reply With Quote
The Following User Says Thank You to AutoPartsWAY For This Useful Post:
Old 07-13-2011, 11:37 AM   #6 (permalink)
checking and/or replacing the filter requires dropping the pan. i'm pretty sure on most toyotas it is a lifetime filter so it does not need changed.
Old 07-13-2011, 11:45 AM   #7 (permalink)
Offical TN Vendor
Depends. We've had customers tell us that their fluid was so dirty they had to replace the filter.
Old 07-13-2011, 05:08 PM   #8 (permalink)
if the fluid is that dirty and the filter needs replaced, wouldn't that indicate something else being very wrong?
Old 07-14-2011, 05:22 AM   #9 (permalink)
Gameroom cash: $254367
View sarsman45's Photo Gallery
Usually means someone is abusing the crap out of the transmission.... either than or the tranny gave up somewhere along the line.
But, given the fact that i recently changed out one with 120K miles and sludge as tranny fluid, a few drain/refills have brought the transmission back to almost new (knock on wood as the sludge hopefully didn't keep the tranny together).
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
