Blowing the fuse means something somewhere in the circuit is short-circuiting. I looked at the circuit diagram and I decided that the most likely culprit is probably your pump, it's really the only load in the circuit. One or some of the windings in the pump are most likely shorted causing the fuse to blow.
Do you let the fuel in the tank get really low sometimes? The fuel actually cools the pump, so if the pump is getting too hot from low fuel then that could possibly cause the windings to short.
SIU Auto, we don't mess around... much
—2005 Silver Streak LE (FINALLY 6speed swapped  )
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
