front end issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2011, 12:16 AM   #1 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
front end issues
I have two issues, and they may be related. This is a 2005 LE with just over 104,000 miles.
First, at highway speeds, unless on exceptionally smooth roads, my steering wheel shakes like crazy...like enough to make my hand start to feel numb after 10-15 minutes.
The tires have been balanced (by a place I trust) and the vibration is the same regardless of where the tires are rotated to or the tire pressure. The car also had a full alignment done by a Toyota dealer less than a month ago. No difference. However, if the road curves to the right, the vibration disappears.
Second, while backing up with the wheel locked/nearly locked left, there is a scraping/grinding noise from the front passenger wheel area. I have checked and the tire is not hitting anything. The brakes all around also have about 70% wear left on them, and the rotors/drums are in excellent shape.
It might be my imagination, but I feel as though my struts are not what they used to be (although nowhere near shot) if that helps any.
Thanks for any input.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 07-15-2011, 11:48 AM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
sounds like it might be the CV joint on your pass. side axle.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 07-15-2011, 01:03 PM   #3 (permalink)
I'll also add in the at least 4-5 months I've had these issues (possibly longer...my memory is crap), it has stayed the same. If it's gotten worse it's not by any noticeable amount.
I don't have any clicking while turning, or most of the classic CV joint symptoms. Would I get the noise both forward and reverse if it was a CV joint? It only happens in reverse...but maybe it's just an early sign. Also, no vibration or anything through the wheel when it makes the noise.
Old 07-16-2011, 02:36 AM   #4 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Check to see if your passenger side control arm rear bushing is ripped or unbonded. Check also for wheel bearing free play.
invader is offline   Reply With Quote
Old 07-18-2011, 04:11 PM   #5 (permalink)
ems
View ems's Photo Gallery
Does the car vibrate more when you hit the gas? If the vibration changes when you hit the gas pedal then it is an inner CV.
ems is offline   Reply With Quote
Old 07-23-2011, 01:36 AM   #6 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Was the tire ever repaired for a puncture???
Have your tires checked. If it is not the wheel balancing, alignment or suspension issue then it must be a bubble in one of the tires due to a bad puncture repair or the tire has become defective over time.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 07-23-2011, 10:44 AM   #7 (permalink)
The control arm bushings look good. I've seen worn out cracked ones before and they look nothing like those. There is also no more free play on the wheel than I've seen on any other car.
The vibration is not affected by either acceleration or braking.
Good suggestion about the tire repair...these have not been repaired, but I did have an issue with that on my old car. Repaired after a flat and a few months later it was shaking like crazy...rubber was all coming apart inside the tire.
I'm beginning to think it's just my struts starting to go combined with the overly craptastic New England roads. Does that sound plausible to anyone?
Old 07-23-2011, 04:50 PM   #8 (permalink)
Could be struts or wheel bearings. Mine only last 60000 miles.
Old 07-23-2011, 10:14 PM   #9 (permalink)
Moderator
Yeah, struts could be a problem where one side strut rebound rate is different than the other.
However, I still don't see it making the car pull to one side on a smooth road since both struts are stationary at that time. Did you try driving it on a smooth road??
Old 07-23-2011, 10:21 PM   #10 (permalink)
On a smooth road it will go straight for miles. Unless there's sizeable bumps, or a large slope to the road, it will keep going straight.
