Help Diagnosing Shimmy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2011, 11:53 AM   #1 (permalink)
View jantzer's Photo Gallery
05 XRS 60k Miles
The problem is only noticeable at highway speeds. The car drives straight. The car brakes straight. I can feel a slight shimmy at higher speeds, but a really ridiculous shimmy when I apply the brakes at freeway speed. I thought it was my front brake rotors and swapped the rotors/pads and no change. I checked the front wheel bearings, no play. I can't see or feel any play on the outer tie rods. If I turn the wheel fast and try and hold onto the tire I can feel a slight vibration and noise as if the steering rack has play maybe??? When the shimmy occurs, the steering wheel shutters back and forth all over the place and I can hear a slight on/off growl of some sort so I know something is shot somewhere.
I appreciate any help!
2006 Tacoma Double Cab Impulse Red
TRD Offroad - 4X4 - Auto - V6
Toytec 3" Lift - 17X9 Centerline Eightball Wheels - 285/70/17 BFG AT's
jantzer is offline   Reply With Quote
Old 07-16-2011, 04:40 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Check to see if your control arms' rear bushing is ripped or unbonded.
invader is offline   Reply With Quote
Old 07-19-2011, 12:12 AM   #3 (permalink)
00 rolla VE
View huangxin's Photo Gallery
Originally Posted by jantzer View Post
05 XRS 60k Miles
Did you check your caliper sliding pins when you were changing out your rotors and pads? Just fixed a similar problem on my civic. Re-greased the sliding pins, problem solved
[IMG]file:///C:/DOCUME%7E1/HP_Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
05 engine under a 00 hood! Another 8th gen is back on the road!
huangxin is offline   Reply With Quote
Old 07-25-2011, 08:47 PM   #4 (permalink)
Calipers pins are free and I re-greased them. The control arm bushings appear fine and I rotated the tires today with no change. I plan on having the tires rebalanced to see if that might be it, but I suspect it's not.
I'm wondering if the caliper could be bad, although the car doesn't pull to either side during breaking.
Old 07-25-2011, 11:34 PM   #5 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Check the steering rack and pinion alongwith steering gears.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
