clutch problem with my corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2011, 05:48 AM   #1 (permalink)
View jakeyseven's Photo Gallery
i noticed the other day , when i parked my car up on my front drive i could here a whirling noise , when i depressed the cluth pedal the sound went away. coukld anyone please help. the car was in nuetrral so the cluth was not under load
jakeyseven is offline   Reply With Quote
Old 07-26-2011, 09:20 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
A bad clutch release bearing would be noisy with clutch released or disengaged, so it's probably the transmission input bearing. What year is your Corolla again, and was the gear lube replaced every 40000 miles?
invader is offline   Reply With Quote
Old 07-28-2011, 03:10 PM   #3 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
i would say trans input bearing, if it was clutch release bearing i think it would have the opposite effect when depressing the clutch pedal.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 07-30-2011, 02:18 AM   #4 (permalink)
View expertmax's Photo Gallery
No you are mixing things up here ! In this case, it's a faulty Clutch Release Bearing.
If you want to do a clutch release bearing job in a garage, you will pay minimum 300$ + parts. If the noise is not that loud, ignore it.
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
Old 07-30-2011, 05:47 PM   #5 (permalink)
The sound goes away with clutch pedal depressed when the clutch release bearing is turning, not when clutch pedal is released and with the transmission input shaft bearing turning. Therefore, it's a noisy transmission input shaft bearing.
Old 07-31-2011, 10:05 PM   #6 (permalink)
That's what I was thinking. Input shaft spins when clutch is engaged, release bearing spins when clutch is released. Bearing will only make noise if it's spinning.
Old 08-01-2011, 01:03 PM   #7 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Your clutch release bearing has gone. 100% that is the issue. You will have to get it replaced.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
